Introduction
This guide will show how to remove the back panel to be able to work inside of the device.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
Pièces
Aucune pièce nécessaire.
Locate the clip on the wiring harness.
  • Locate the clip on the wiring harness.
Ajouter un commentaire
Press down on the clip like you would an Ethernet cable. Rock harness side to side, pulling gently towards you until harness detaches.
  • Press down on the clip like you would an Ethernet cable.
  • Rock harness side to side, pulling gently towards you until harness detaches.
Locate back panel.
  • Locate back panel.
Remove four 11.5mm Phillips #00 (silver) screws from back panel. Remove four 11.5mm Phillips #00 (silver) screws from back panel. Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
Remove four 9.5mm Phillips #00 (black) screws from back panel.
  • Remove four 9.5mm Phillips #00 (black) screws from back panel.
  • Remove two 7.5mm Phillips #00 (black) screws from back panel.
Remove back panel.
  • Remove back panel.
  • On the back panel there will be thermal (white) paste. Do not touch.
Odelkys Marquez
Membre depuis le 22/09/2014
898 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 10-2, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 445
