Introduction
This will be the initial step for getting into your device for repair.
Before any repair work can be done, one must remove the device from the vehicle. To do so follow this link to see a vehicle general removal of a stereo system.
Pièces
Aucune pièce nécessaire.
Locate face-plate eject button.
  • Locate face-plate eject button.
Ajouter un commentaire
Press the eject button. Remove the face-plate.
  • Press the eject button.
  • Remove the face-plate.
Remove two 4.9mm Phillips #00screws on the front of the device. Remove two 7.5mm Phillips #00screws on the front of the device. When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
  • Remove two 4.9mm Phillips #00screws on the front of the device.
  • Remove two 7.5mm Phillips #00screws on the front of the device.
  • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
The screws in red do not seem to need to be removed unless you are trying to replace the eject lever. If you're not trying to replace the lever, it adds an unnecessary complication to putting it back together.
Dale Pearson - Réponse
Rotate device 90 degrees to either side. Use the plastic opening tool to pry open the top and bottom tab respectively.
  • Rotate device 90 degrees to either side.
  • Use the plastic opening tool to pry open the top and bottom tab respectively.
  • Repeat on opposite side.
Remove front panel.
  • Remove front panel.
2 autre(s) ont terminé cette réparation.
Odelkys Marquez
Membre depuis le 22/09/2014
898 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 10-2, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 36
Total : 1,331
