Aller au contenu principal
Sony Clie PEG-NR70 Battery Pack Replacement
Ce dont vous avez besoin
  1. Sony Clie PEG-NR70 Battery Pack Replacement, The Case: étape 1, image 1 de 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Battery Pack Replacement: étape 2, image 1 de 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Battery Pack Replacement: étape 3, image 1 de 2 Sony Clie PEG-NR70 Battery Pack Replacement: étape 3, image 2 de 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: étape 4, image 1 de 2 Sony Clie PEG-NR70 Battery Pack Replacement, Battery Pack: étape 4, image 2 de 2
    • Pull up on the black tab on the battery pack to reveal the power cord.
  5. Sony Clie PEG-NR70 Battery Pack Replacement: étape 5, image 1 de 1
    • Disconnect the battery pack from the motherboard by unplugging the power cables. Gently pull the wire toward the bottom of the device.
    • Be careful to not tear the cables! They are very thin.
  6. Sony Clie PEG-NR70 Battery Pack Replacement: étape 6, image 1 de 1
    • Gently peel back the adhesive to completely disconnect the battery pack from device.
3 autres ont terminé cette réparation.
Courtney
Membre depuis le 04/19/13
49 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-11, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 membres
8 tutoriels rédigés
Un commentaire
Hi, this is really helpful, thank you.
Richard Hancock - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 10
Total : 2,150
