Aller au contenu principal
Sony Clie PEG-NR70 Speaker Rail Replacement
Ce dont vous avez besoin
  1. Sony Clie PEG-NR70 Speaker Rail Replacement, The Case: étape 1, image 1 de 1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Sony Clie PEG-NR70 Speaker Rail Replacement: étape 2, image 1 de 1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Speaker Rail Replacement: étape 3, image 1 de 2 Sony Clie PEG-NR70 Speaker Rail Replacement: étape 3, image 2 de 2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
  4. Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: étape 4, image 1 de 2 Sony Clie PEG-NR70 Speaker Rail Replacement, Speaker Rail: étape 4, image 2 de 2
    • Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
    • Be careful not to tear the speaker wires! They are very thin.
    • Remove the tape holding speaker wire by peeling it away.
  5. Sony Clie PEG-NR70 Speaker Rail Replacement: étape 5, image 1 de 1
    • Holding down the speaker rail unscrew the two 2.5mm screws with a Phillips #00 screwdriver.
    • Remove the speaker rail vertically from the device.
Daniel Soski
Membre depuis le 04/18/13
57 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-11, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 300
