Aller au contenu principal
Sony Clie PEG-T615C Thumb Dial Replacement
Ce dont vous avez besoin
  1. Sony Clie PEG-T615C Thumb Dial Replacement, Thumb Dial: étape 1, image 1 de 1
    • First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
  2. Sony Clie PEG-T615C Thumb Dial Replacement: étape 2, image 1 de 1
    • Remove the screw directly above the thumb dial panel.
  3. Sony Clie PEG-T615C Thumb Dial Replacement: étape 3, image 1 de 1
    • Remove the screw from thumb dial panel on the right handed side of the device.
  4. Sony Clie PEG-T615C Thumb Dial Replacement: étape 4, image 1 de 1
    • Remove screw from lower right side of the device.
  5. Sony Clie PEG-T615C Thumb Dial Replacement: étape 5, image 1 de 1
    • Remove 1 screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Thumb Dial Replacement: étape 6, image 1 de 1
    • On the bottom of the device, remove both the left and right screws.
  7. Sony Clie PEG-T615C Thumb Dial Replacement: étape 7, image 1 de 1
    • Remove the thumb dial panel by sliding it away from the device.
  8. Sony Clie PEG-T615C Thumb Dial Replacement: étape 8, image 1 de 1
    • Remove the back panel exposing the inside of the device.
  9. Sony Clie PEG-T615C Thumb Dial Replacement: étape 9, image 1 de 1
    • Locate thumb dial on top right side of the board.
  10. Sony Clie PEG-T615C Thumb Dial Replacement: étape 10, image 1 de 1
    • Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
  11. Sony Clie PEG-T615C Thumb Dial Replacement: étape 11, image 1 de 1
    • Pull plug straight up to remove from board.
Rob
Membre depuis le 10/04/11
1 Réputation
2 tutoriels rédigés
Équipe
UW Stout, Team 5-6, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 15
Total : 1,065
