Introduction
Before taking apart your device, make sure that you have the proper tools to do so. We used a small screwdriver to remove the screws because they are so tiny. Also, make sure that you are working in an area that is clean and clear of debris so you can see all the parts of your device as you take it apart.
Pièces
Aucune pièce nécessaire.
Remove screws on the black plate and the side of the device. Remove screws on the black plate and the side of the device.
  • Remove screws on the black plate and the side of the device.
Ajouter un commentaire
Remove the small top grey piece from the back plate Detach the back plate from the rest of the device.
  • Remove the small top grey piece from the back plate
  • Detach the back plate from the rest of the device.
Loosen and remove the screws on the motherboard.
  • Loosen and remove the screws on the motherboard.
Remove volume rocker from side panel of device.
  • Remove volume rocker from side panel of device.
Loosen the battery from the motherboard.
  • Loosen the battery from the motherboard.
  • Replace battery with a new one.
Insert the new battery into the device.
  • Insert the new battery into the device.
Alyson
Membre depuis le 18/10/2011
11 Réputation
1 tutoriel rédigé
Équipe
James Madison, Team 1-2, Allen Fall 2011 Membre de l'équipe James Madison, Team 1-2, Allen Fall 2011
JMU-ALLEN-F11S1G2
3 membres
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 1,737
