Introduction
Si l'unité d'affichage LCD de votre Sony Cyber-Shot DSC-W120 est endommagée, ce guide vous guidera tout au long du processus de localisation et de retrait.
Ce dont vous avez besoin
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Un commentaire
Hi, for step 8 the wider of the two ribbon cables is held by a black/dark grey clamp on the connector on the motherboard, it's best to release the clamp before pulling the cable out.
Do that by gently lifting it with a fingernail, it hinges on the screen side, it will rotate about 90 degrees to open. When reassembling it's simply the reverse, so push the cable in to the connector with the clamp open, when the cable is fully in there will be about 1mm of the gold connectors on the ribbon cable showing still, and then just clamp connector clamp shut but pushing it with your thumb.
