Introduction
This guide will teach you how to take off the screen on the Sony Cyber-shot DSC-H300.
Pièces
Aucune pièce nécessaire.
Remove the 6mm Phillips #000 screws. Remove the 6mm Phillips #000 screws. Remove the 6mm Phillips #000 screws.
  • Remove the 6mm Phillips #000 screws.
Ajouter un commentaire
Remove the five 6mm Phillips #000 screws. Remove the four 3mm Phillips #000 screws. Remove the four 3mm Phillips #000 screws.
  • Remove the five 6mm Phillips #000 screws.
  • Remove the four 3mm Phillips #000 screws.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Use the flat end of a  plastic spudger to pry apart the rear cover from the body of the camera.
  • Use the flat end of a plastic spudger to pry apart the rear cover from the body of the camera.
Remove the two 6mm Phillips #000 screws.
  • Remove the two 6mm Phillips #000 screws.
The screen will be loose so remove it.
  • The screen will be loose so remove it.
Zachary Meyer
Membre depuis le 14/02/2018
377 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S1-G6, Nance Spring 2018
USFT-NANCE-S18S1G6
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 17
Total : 46
