Introduction
This guide explains how to remove and replace the shutter motor in the Sony Cybershot DSC-P52
Open the battery compartment and remove the batteries.
  • Open the battery compartment and remove the batteries.
  • Remove all of the visible screws on the outside of the case.
  • There should be three of them that are all easily located.
Ajouter un commentaire
Open the memory card compartment.
  • Open the memory card compartment.
  • Remove the screw next to the memory card slot.
Pull apart the front and back cover pieces carefully.
  • Pull apart the front and back cover pieces carefully.
  • The front cover should come completely free with little effort.
  • The back cover will still be attached to the circuit board.
Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
  • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
  • The circuitry will still be connected to the back case by ribbon cables.
Open the case as shown.
  • Open the case as shown.
Unclip the clip holding the ribbon cable in.
  • Unclip the clip holding the ribbon cable in.
  • Other ribbon cables might not have a clips.
Pull the ribbon cable out.
  • Pull the ribbon cable out.
Remove all six screws on the front side of the motherboard circled in the picture.
  • Remove all six screws on the front side of the motherboard circled in the picture.
  • Pull the motherboard from the rest of the housing.
  • It will still be connected to the flash unit.
Remove the cable on the back side of the motherboard.
  • Remove the cable on the back side of the motherboard.
Detach the ribbon cables shown.
  • Detach the ribbon cables shown.
  • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
  • Remove the flash unit from the motherboard.
Remove screw securing motor and mount in place.
  • Remove screw securing motor and mount in place.
  • Be careful to leave shutter gears in the correct position
Remove the two screws holding motor to mount/gears.
  • Remove the two screws holding motor to mount/gears.
  • Remove the motor from the mount.
Greg Hermansen
Membre depuis le 28/01/2011
25 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 3-43, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 4,455
