Introduction
Is your LCD screen acting strange? Replacing the CCD Sensor Module is a straight forward task that will increase the clarity of your screen.
Pièces
Aucune pièce nécessaire.
Locate the battery door at the bottom of the camera. Press down on the door and  slide it back.  The door will pop open.
  • Locate the battery door at the bottom of the camera.
  • Press down on the door and slide it back. The door will pop open.
Ajouter un commentaire
Remove the battery.
  • Remove the battery.
There are two screws on the left and right sides of the camera, and two screws on the bottom. Use a PH00 screwdriver and remove the six 2.9mm screws. Use a PH00 screwdriver and remove the six 2.9mm screws.
  • There are two screws on the left and right sides of the camera, and two screws on the bottom.
  • Use a PH00 screwdriver and remove the six 2.9mm screws.
Use hands to gently pry the front casing away from the camera. Use hands to gently pry the front casing away from the camera.
  • Use hands to gently pry the front casing away from the camera.
Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable. The second picture shows what these tabs look like in their open positions.
  • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
  • The second picture shows what these tabs look like in their open positions.
Grasp the CCD Sensor Module and remove it.
  • Grasp the CCD Sensor Module and remove it.
2 autre(s) ont terminé cette réparation.
iDeleted
Membre depuis le 07/07/2010
2 101 Réputation
41 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 18
Total : 11,363
