Aller au contenu principal
Sony Cyber-shot DSC-T1 LCD screen Replacement
Ce dont vous avez besoin
  1. Sony Cyber-shot DSC-T1 LCD screen Replacement, Battery: étape 1, image 1 de 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 2, image 1 de 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: étape 3, image 1 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: étape 3, image 2 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement, Flash: étape 3, image 3 de 3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
  4. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 4, image 1 de 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 5, image 1 de 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 6, image 1 de 1
    • After releasing the clips, pull out black lens box.
  7. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 7, image 1 de 2 Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 7, image 2 de 2
    • Use the plastic opening tool to flip the clip.
  8. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 8, image 1 de 2 Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 8, image 2 de 2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
  9. Sony Cyber-shot DSC-T1 LCD screen Replacement, LCD screen: étape 9, image 1 de 1
    • Use the plastic opening tool to flip the top clip that holds the ribbon to the motherboard unit.
  10. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 10, image 1 de 2 Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 10, image 2 de 2
    • Flip the motherboard unit up to expose the metal plate beneath it.
    • Remove the four 3mm screws shown using the 00 screwdriver.
  11. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 11, image 1 de 1
    • Lift and remove the metal plate covering the LCD screen from the camera.
  12. Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 12, image 1 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 12, image 2 de 3 Sony Cyber-shot DSC-T1 LCD screen Replacement: étape 12, image 3 de 3
    • Flip the LCD over to the other side of the camera.
    • Peel the tape connecting the LCD to the camera.
    • Remove LCD screen
Paul Elrich
Membre depuis le 04/12/12
33 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-35, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 55
Total : 3,253
