Introduction
The sliding lens cover is on the front of the camera, and moves vertically to hide or expose the lens and flash. It may need to be replaced if it becomes stuck.
Pièces
Aucune pièce nécessaire.
Remove screws from outside of camera. There are 6 screws total. 3 screws on underside. 1 screw on right side, near battery cover.
  • Remove screws from outside of camera. There are 6 screws total.
  • 3 screws on underside.
  • 1 screw on right side, near battery cover.
  • 2 screws on left side.
Ajouter un commentaire
Use screwdriver to remove screws.
  • Use screwdriver to remove screws.
Gently pull the front cover off of the main camera.
  • Gently pull the front cover off of the main camera.
  • All of the inner parts of the camera are attached to the back screen.
The front cover is now removed from the camera and the internal hardware is now exposed.
  • The front cover is now removed from the camera and the internal hardware is now exposed.
The front sliding lens cover.
  • The front sliding lens cover.
Remove four screws using Phillips located on the inside of the front cover. Remove four screws using Phillips located on the inside of the front cover.
  • Remove four screws using Phillips located on the inside of the front cover.
Remove front sliding lens cover. Remove front sliding lens cover.
  • Remove front sliding lens cover.
The front sliding lens cover is now removed and may be repair or replaced. The front sliding lens cover is now removed and may be repair or replaced.
  • The front sliding lens cover is now removed and may be repair or replaced.
Stephannie Allen
Membre depuis le 11/03/2013
189 Réputation
10 tutoriels rédigés
Équipe
Clemson, Team 13-1, Benson Spring 2013 Membre de l'équipe Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 membres
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 592
