Introduction
Knowledge of how to remove the outer casing is necessary to replace it. (See guide)
Pièces
Aucune pièce nécessaire.
Find the hatch labeled "open" on the left side of the bottom of the camera.
  • Find the hatch labeled "open" on the left side of the bottom of the camera.
  • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Ajouter un commentaire
Slide the blue locking tab to release the battery. Slide the battery out of the camera.
  • Slide the blue locking tab to release the battery. Slide the battery out of the camera.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera. Remove the four 2.5mm Philips #0 screws.
  • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
  • Remove the four 2.5mm Philips #0 screws.
Turn the camera so the left side-panel faces you. (It says 5x Optical Zoom) Remove the two 2.5mm Philips #0 screws. You may have to remove the screws with a pair of tweezers when the screws are almost out.
  • Turn the camera so the left side-panel faces you. (It says 5x Optical Zoom)
  • Remove the two 2.5mm Philips #0 screws.
  • You may have to remove the screws with a pair of tweezers when the screws are almost out.
Turn the camera so the right side faces you. Remove the two 2.5mm Philips #0 screws. You may have to remove the screws with a pair of tweezers when the screws are almost out.
  • Turn the camera so the right side faces you.
Rotate camera so that the back is facing you.
  • Rotate camera so that the back is facing you.
  • Pull the back casing directly away from the LCD screen.
Turn the camera so that the left side is facing you. Pull the left side-panel off of the camera.
  • Turn the camera so that the left side is facing you.
  • Pull the left side-panel off of the camera.
Turn camera so that the front of the camara is facing you. Pull the front casing directly away from the camera.
  • Turn camera so that the front of the camara is facing you.
  • Pull the front casing directly away from the camera.
  • The right side panel may fall off when you take the front panel off.
Turn the camera so that the right side is facing you. Pull the right side-panel away from the rest of the camera.
  • Turn the camera so that the right side is facing you.
  • Pull the right side-panel away from the rest of the camera.
This is what your camera should look like now that you have removed the casing from all sides. This is what your camera should look like now that you have removed the casing from all sides.
  • This is what your camera should look like now that you have removed the casing from all sides.
Evan Mayer
Membre depuis le 05/10/2010
318 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 7-54, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 1,636
