Introduction
This repair guide will number and display the steps to remove the Motherboard for replacement.
Slide the battery cover in the direction the arrow points. Pull the battery cover towards you.
  • Slide the battery cover in the direction the arrow points.
  • Pull the battery cover towards you.
Ajouter un commentaire
Flick the blue switch for the battery to pop out. Remove the battery from the camera.
  • Flick the blue switch for the battery to pop out.
  • Remove the battery from the camera.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel. Remove that panel.
  • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
  • Remove that panel.
  • Careful for falling pieces.
Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel). Remove that panel.
  • Remove the screw with a Phillips #00 Screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
  • Remove the screw using the Phillips #00 Screwdriver from the bottom the camera, closest to the back cover.
Gently remove the back cover. It may be a bit stiff, so use some force to remove it. Proceed with caution.
  • Gently remove the back cover.
  • It may be a bit stiff, so use some force to remove it. Proceed with caution.
Remove the screw using a Phillips #00 Screwdriver on the left side (where the "3x optical zoom" panel use to be).
  • Remove the screw using a Phillips #00 Screwdriver on the left side (where the "3x optical zoom" panel use to be).
Remove the small screw using a Phillips #00 Screwdriver on the bottom of the camera attached to the front cover. Gently remove the front cover. Put a little force to pop off the case. Proceed with caution.
  • Remove the small screw using a Phillips #00 Screwdriver on the bottom of the camera attached to the front cover.
  • Gently remove the front cover.
  • Put a little force to pop off the case. Proceed with caution.
Flip the black secure locks off. Tweezers may be necessary. Detach the two  orange cables.
  • Flip the black secure locks off. Tweezers may be necessary.
  • Detach the two orange cables.
Gently pull the lens container out of the camera. Gently pull the lens container out of the camera.
  • Gently pull the lens container out of the camera.
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
Remove the two orange cables on the top of the motherboard with tweezers. Lift the motherboard out of its slot.
  • Remove the two orange cables on the top of the motherboard with tweezers.
  • Lift the motherboard out of its slot.
For the AV port, detach the bottom orange cable. For the LCD screen, detach the top orange cable on the right side of the motherboard.
  • For the AV port, detach the bottom orange cable.
  • For the LCD screen, detach the top orange cable on the right side of the motherboard.
  • For the motherboard, detach all the orange cables.
  • Careful not to damage the red, white, and black wires when lifting the board.
Christopher Wakamatsu
Membre depuis le 11/10/2010
90 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-20, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 3,192
