Introduction
This guide shows how to replace the outer case if damaged.
Pièces
Aucune pièce nécessaire.
Slide the gray switch from lock to open position.
  • Slide the gray switch from lock to open position.
Ajouter un commentaire
Pull down on the blue tab to release the battery. Pull down on the blue tab to release the battery.
  • Pull down on the blue tab to release the battery.
Use a PH00 screwdriver to remove the  five 3.5 mm screws. Use a PH00 screwdriver to remove the two 2.5 mm screws. Use a PH00 screwdriver to remove the two 2.5 mm screws.
  • Use a PH00 screwdriver to remove the five 3.5 mm screws.
  • Use a PH00 screwdriver to remove the two 2.5 mm screws.
Pry apart the case gently using a plastic opening tool. Pry apart the case gently using a plastic opening tool.
  • Pry apart the case gently using a plastic opening tool.
Kate Glazer
Membre depuis le 20/03/2018
579 Réputation
5 tutoriels rédigés
Équipe
IUPUI, Team S6-G3, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 36
