Aller au contenu principal
Sony DVP-FX730 Cover Replacement
Ce dont vous avez besoin
  1. Sony DVP-FX730 Cover Replacement, Cover: étape 1, image 1 de 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: étape 2, image 1 de 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: étape 3, image 1 de 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: étape 4, image 1 de 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
Rogelio Garcia
Membre depuis le 01/20/12
19 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-21, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,451
