Aller au contenu principal
Sony DVP-FX730 Monitor Replacement
Ce dont vous avez besoin
  1. Sony DVP-FX730 Monitor Replacement, Cover: étape 1, image 1 de 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: étape 2, image 1 de 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: étape 3, image 1 de 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: étape 4, image 1 de 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: étape 5, image 1 de 2 Sony DVP-FX730 Monitor Replacement, Monitor: étape 5, image 2 de 2
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: étape 6, image 1 de 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: étape 7, image 1 de 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: étape 8, image 1 de 2 Sony DVP-FX730 Monitor Replacement: étape 8, image 2 de 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: étape 9, image 1 de 2 Sony DVP-FX730 Monitor Replacement: étape 9, image 2 de 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: étape 10, image 1 de 1
    • The screen should now be completely separated from the main device.
Andrew Ward
Membre depuis le 01/20/12
93 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-21, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 3,013
