Aller au contenu principal
Sony DVP-FX730 Screen Replacement
Ce dont vous avez besoin
  1. Sony DVP-FX730 Screen Replacement, Monitor: étape 1, image 1 de 2 Sony DVP-FX730 Screen Replacement, Monitor: étape 1, image 2 de 2
    • Use your hand to remove the small back cover by gently pulling upward.
  2. Sony DVP-FX730 Screen Replacement: étape 2, image 1 de 1
    • Using a screwdriver, remove the two 12 mm pan head screws.
  3. Sony DVP-FX730 Screen Replacement: étape 3, image 1 de 1
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  4. Sony DVP-FX730 Screen Replacement: étape 4, image 1 de 2 Sony DVP-FX730 Screen Replacement: étape 4, image 2 de 2
    • Remove the wires attached to the white base using tweezers to pull them up.
  5. Sony DVP-FX730 Screen Replacement: étape 5, image 1 de 2 Sony DVP-FX730 Screen Replacement: étape 5, image 2 de 2
    • Referring back to Step 8, do the same with the wires attached to the black base.
  6. Sony DVP-FX730 Screen Replacement: étape 6, image 1 de 1
    • The screen should now be completely separated from the main device.
  7. Sony DVP-FX730 Screen Replacement, Screen: étape 7, image 1 de 1
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  8. Sony DVP-FX730 Screen Replacement: étape 8, image 1 de 1
    • Using the spudger, separate the top and bottom covers.
  9. Sony DVP-FX730 Screen Replacement: étape 9, image 1 de 1
    • Identify the gray back of the screen.
  10. Sony DVP-FX730 Screen Replacement: étape 10, image 1 de 1
    • Remove the screws.
  11. Sony DVP-FX730 Screen Replacement: étape 11, image 1 de 1
    • Remove the metal plates.
  12. Sony DVP-FX730 Screen Replacement: étape 12, image 1 de 2 Sony DVP-FX730 Screen Replacement: étape 12, image 2 de 2
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  13. Sony DVP-FX730 Screen Replacement: étape 13, image 1 de 2 Sony DVP-FX730 Screen Replacement: étape 13, image 2 de 2
    • Place your hand on the front of the screen and push upwards.
2 autres ont terminé cette réparation.
Oliver Woolsoncroft
Membre depuis le 01/20/12
78 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-21, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 2,709
