Introduction
Buy a new AA battery of any brand you like.
Outils
Pièces
Aucune pièce nécessaire.
Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
  • Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
Ajouter un commentaire
Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible. Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
  • Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
  • To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone. Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
  • Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
Reconnect the bottom and top base of the microphone by pushing them together.
  • Reconnect the bottom and top base of the microphone by pushing them together.
Attach the bottom base by turning it counter-clockwise.
  • Attach the bottom base by turning it counter-clockwise.
Place the windshield back onto the top of the microphone.
  • Place the windshield back onto the top of the microphone.
Insert stereo jack of microphone into external device. Test the microphone. This should fix the problem, otherwise issues may exist elsewhere. Insert stereo jack of microphone into external device. Test the microphone. This should fix the problem, otherwise issues may exist elsewhere.
  • Insert stereo jack of microphone into external device. Test the microphone. This should fix the problem, otherwise issues may exist elsewhere.
2 autre(s) ont terminé cette réparation.
Kefaya
Membre depuis le 23/01/2014
343 Réputation
3 tutoriels rédigés
Équipe
New Mexico State, Team 1-2, Sheppard Spring 2014 Membre de l'équipe New Mexico State, Team 1-2, Sheppard Spring 2014
NMSU-SHEPPARD-S14S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 36
Total : 2,380
