Aller au contenu principal
Sony Ericsson Xperia Play Main Flex Cable Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: étape 1, image 1 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: étape 1, image 2 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: étape 1, image 3 de 3
    • Remove the battery cover and the battery.
    • You have 6x silver screw and 7x black screw and remove the rear bezel.
  2. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 2, image 1 de 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 2, image 2 de 2
    • Now with a plastic tool disconnect the main flex cable. Be careful, near to the main flex cable connector there is many small elements.
    • Disconnect the gaming keyboard flex keyboard.
  3. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 3, image 1 de 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 3, image 2 de 2
    • Remove the mother board and the gaming keyboard.
  4. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 4, image 1 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 4, image 2 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 4, image 3 de 3
    • Unscrew the 4x screws.
    • Remove the black sticker.
    • Disconnect the touchscreen flex cable connector.
    • Now you can disassemble the front bezel.
  5. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 5, image 1 de 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 5, image 2 de 2
    • Use the thin end of a plastic tool to remove LCD Display and disconnect the flex cable.
  6. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 6, image 1 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 6, image 2 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 6, image 3 de 3
    • To release the ribbon cable peel off two patches.
  7. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 7, image 1 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 7, image 2 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 7, image 3 de 3
    • Now remove the small metal plate taped to the flex cable.
    • Remove the plastic plate from the back side of the flex cable connector.
    • Bend the cable at an angle so you can push it down through the hole.
  8. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 8, image 1 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 8, image 2 de 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 8, image 3 de 3
    • Use the same technique when you are installing the new Main Ribbon Cable.
    • I prefer to test the new spare part before the full assembly.
  9. Sony Ericsson Xperia Play Main Flex Cable Replacement: étape 9, image 1 de 1
5 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 278 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
3 commentaires
Iv got a problem my phone won't turn on or charge but when i plug the charger in the power button just flashes red a couple of times then nothing do u know what this means is it the battery or the phone that is broke
paulfrost412 - Réponse
Is "small metal plate" from Step 7 important? Forgot to put it inside and if there is no need to open it again (everything works) I won't do it :)
ch3mn3y - Réponse
vreau sa cumpar sleif la xperia play, rog foarte muld daca aveti ceva informatii sunati sau scrieti pe mob; 060215747.
petrea - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 48
Total : 7,395
