Introduction
The headphone jack will need to be replaced it it no longer outputs audio.
Open the flaps and remove the back cover using the plastic opening device. Open the flaps and remove the back cover using the plastic opening device. Open the flaps and remove the back cover using the plastic opening device.
  • Open the flaps and remove the back cover using the plastic opening device.
Ajouter un commentaire
Remove the battery shield with the plastic opening device. Remove the battery shield with the plastic opening device.
  • Remove the battery shield with the plastic opening device.
Remove the battery. Remove the battery.
  • Remove the battery.
Unscrew the 5mm screws with the T5 head.
  • Unscrew the 5mm screws with the T5 head.
  • Unscrew the 6mm screw with the T6 head.
Remove the black cover with the plastic opening tool. Remove the headphone jack from its slot.
  • Remove the black cover with the plastic opening tool.
  • Remove the headphone jack from its slot.
3 autre(s) ont terminé cette réparation.
Daniel
Membre depuis le 13/10/2014
412 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 14-5, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 482
