Pièces
Aucune pièce nécessaire.
Note: This camera came without a battery, thus all pictures shown will be missing a battery.
  • Note: This camera came without a battery, thus all pictures shown will be missing a battery.
  • Locate the battery pack which can be found on the back side of the camera below the viewfinder.
  • Push in the small button on the bottom of the camera, marked with the red circle, then slide the entire switch forward, marked with the yellow rectangle.
Ajouter un commentaire
Slide the battery out of the back of the camera.
  • Slide the battery out of the back of the camera.
  • The battery can be inserted by sliding it back into place in a similar manner to how it was removed.
Remove the (6) 4.5mm screws from the bottom of the Sony Handycam that are marked with small circles.
  • Remove the (6) 4.5mm screws from the bottom of the Sony Handycam that are marked with small circles.
  • Note: You will use the #00 Philips Screwdriver for this part and in all subsequent slides.
  • Note: Most screws that are meant to be removed are marked with arrows on the camera itself.
Remove (3) 4.5mm screws from underneath the battery.  Again they are marked by small arrows. Remove (1) 2.9mm screw from the right corner.
  • Remove (3) 4.5mm screws from underneath the battery. Again they are marked by small arrows.
  • Remove (1) 2.9mm screw from the right corner.
  • Remove (2) 4.5mm screws from the battery right wall.
  • Note: The battery has been removed for these steps.
Remove (1) 4.5mm screw from underneath the output flap on the front of the camera right below the lens.
  • Remove (1) 4.5mm screw from underneath the output flap on the front of the camera right below the lens.
Remove the (2) 4.5mm screws from the top of the camera that are pointed out with red circles. Remove the (1) 4.5 mm screw from the disk side of the camera located next to the lens. This screw is pointed out with a yellow circle.
  • Remove the (2) 4.5mm screws from the top of the camera that are pointed out with red circles.
  • Remove the (1) 4.5 mm screw from the disk side of the camera located next to the lens. This screw is pointed out with a yellow circle.
Extend the gray viewfinder so the black, plastic casing will have room to come off. Remove the black plastic casing gently from the top of the camera. Use caution because the plastic pieces are fragile and tend to break easily.
  • Extend the gray viewfinder so the black, plastic casing will have room to come off.
  • Remove the black plastic casing gently from the top of the camera. Use caution because the plastic pieces are fragile and tend to break easily.
Remove (2) 2.9mm screws from under the black plastic casing that was mentioned in the previous step.
  • Remove (2) 2.9mm screws from under the black plastic casing that was mentioned in the previous step.
Caution: Carefully pull off the outer silver case along with screen.
  • Caution: Carefully pull off the outer silver case along with screen.
  • Note: The copper wire strip still connecting the cover to the body of the camera must be removed. It is pointed out with a red square in the slide.
kaitlin
Membre depuis le 11/01/2011
330 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-44, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,164
