Aller au contenu principal
Sony PlayStation 3D Display 3D Sync Transmitter Replacement
Ce dont vous avez besoin
  1. Sony PlayStation 3D Display 3D Sync Transmitter Replacement, Rear Case: étape 1, image 1 de 2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 2, image 1 de 3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 2, image 2 de 3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 2, image 3 de 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 3, image 1 de 2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 3, image 2 de 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 4, image 1 de 3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 4, image 2 de 3 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 4, image 3 de 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display 3D Sync Transmitter Replacement, 3D Sync Transmitter: étape 5, image 1 de 2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement, 3D Sync Transmitter: étape 5, image 2 de 2
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws that hold the 3D Sync Transmitter in place.
  6. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 6, image 1 de 1
    • Carefully pry off the 3D Sync Transmitter with the plastic opening tool.
    • Use the plastic opening tool to pry at both ends and not from the center as to avoid breaking the 3D Sync Transmitter.
  7. Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 7, image 1 de 2 Sony PlayStation 3D Display 3D Sync Transmitter Replacement: étape 7, image 2 de 2
    • Pry the tab slightly up with your thumbnail and pull the connector away from the board.
2 autres ont terminé cette réparation.
Tia McNaughton
Membre depuis le 10/01/15
379 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-16, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 17
Total : 2,261
