Aller au contenu principal
Sony PlayStation 3D Display Side Speakers Replacement
Ce dont vous avez besoin
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: étape 1, image 1 de 2 Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: étape 1, image 2 de 2
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: étape 2, image 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement: étape 2, image 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement: étape 2, image 3 de 3
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: étape 3, image 1 de 2 Sony PlayStation 3D Display Side Speakers Replacement: étape 3, image 2 de 2
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: étape 4, image 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement: étape 4, image 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement: étape 4, image 3 de 3
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: étape 5, image 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: étape 5, image 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: étape 5, image 3 de 3
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: étape 6, image 1 de 3 Sony PlayStation 3D Display Side Speakers Replacement: étape 6, image 2 de 3 Sony PlayStation 3D Display Side Speakers Replacement: étape 6, image 3 de 3
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: étape 7, image 1 de 2 Sony PlayStation 3D Display Side Speakers Replacement: étape 7, image 2 de 2
    • Remove the speaker by depressing the white tab on the speaker wire connector.
3 autres ont terminé cette réparation.
viharim
Membre depuis le 10/22/15
200 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 12-16, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 membres
8 tutoriels rédigés
Un commentaire
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 31
Total : 2,550
