Introduction
This Audio System is the model SRS-XB30. Common malfunctions of this Audio System include its failing speakers, charging incapability, and Bluetooth pairing impairment.
Ce dont vous avez besoin
To remove the speaker grill, insert the big spudger underneath it in each corner.
24 autres ont terminé cette réparation.
8 commentaires
Hello. Would you upload a detailed photo of the motherboard and the built-in amplifier? I’d like to know if I could find the right IC which I want to change. Thank you! and great guide!
Can you help with what kind of battery I need? I would like to purchase it before I take everything apart. Thank you.
Here you can see the answer. https://www.amazon.com/Replacement-SRS-X...
I really like the sound of this BT device. That´s why I own one of these. I just want to know how to convert this rechargeable speaker into AC power supply device because I don´t want to buy a battery replacement when the original one runs out. I don´t know how to calculate the volts and amperes needed to supply this speaker.
Which adhesive should be bought to put it all back together? Are there parts which can break or go in unoriginal form and should be romoved or fixed back together carefully? Also the link for the battery on amazon which is posted cant supply right now: is there any alternatives?
Thank you for making this guide and helping out :D
