Aller au contenu principal
Sony SRS-XB30 Charging Port Replacement
Ce dont vous avez besoin
  1. Sony SRS-XB30 Charging Port Replacement, Battery: étape 1, image 1 de 1
    • To remove the speaker grill, insert the big spudger underneath it in each corner.
    • Work around the edges to pry the grill up and off.
  2. Sony SRS-XB30 Charging Port Replacement: étape 2, image 1 de 2 Sony SRS-XB30 Charging Port Replacement: étape 2, image 2 de 2
    • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
    • This will need to be done on all four sides of the speaker to remove all four panels
    • This requires some effort because the adhesive is sticky.
  3. Sony SRS-XB30 Charging Port Replacement: étape 3, image 1 de 2 Sony SRS-XB30 Charging Port Replacement: étape 3, image 2 de 2
    • Locate the four screws on the now exposed front panel.
    • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
  4. Sony SRS-XB30 Charging Port Replacement: étape 4, image 1 de 1
    • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
    • Use the same T7 screwdriver head here.
    • Remove each of the four corner screws (15.0 mm long).
  5. Sony SRS-XB30 Charging Port Replacement: étape 5, image 1 de 1
    • With a little force, carefully lift the lid of the speaker.
    • Make sure that you do not pull on the wires.
  6. Sony SRS-XB30 Charging Port Replacement: étape 6, image 1 de 3 Sony SRS-XB30 Charging Port Replacement: étape 6, image 2 de 3 Sony SRS-XB30 Charging Port Replacement: étape 6, image 3 de 3
    • Unclip the four wire connectors (that are attached to the speaker lid).
    • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
  7. Sony SRS-XB30 Charging Port Replacement: étape 7, image 1 de 1
    • Separate the speaker lid from the bottom frame.
    • To prepare the speaker for the next step place the lid parallel to the frame.
  8. Sony SRS-XB30 Charging Port Replacement: étape 8, image 1 de 1
    • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
    • Using the screwdriver with bit PH1, unscrew each screw.
  9. Sony SRS-XB30 Charging Port Replacement: étape 9, image 1 de 1
    • Separate the speaker lid entirely from the bottom frame.
  10. Sony SRS-XB30 Charging Port Replacement: étape 10, image 1 de 1
    • Remove the top screw (10 mm).
    • Use the screwdriver with bit T7.
  11. Sony SRS-XB30 Charging Port Replacement: étape 11, image 1 de 2 Sony SRS-XB30 Charging Port Replacement: étape 11, image 2 de 2
    • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
    • There are two screws on the left side of the white box and one to its right.
  12. Sony SRS-XB30 Charging Port Replacement: étape 12, image 1 de 1
    • Slightly lift the white box with all the wires still attached.
  13. Sony SRS-XB30 Charging Port Replacement: étape 13, image 1 de 2 Sony SRS-XB30 Charging Port Replacement: étape 13, image 2 de 2
    • Take the big spudger and pry the black casing up from the circuit box.
  14. Sony SRS-XB30 Charging Port Replacement: étape 14, image 1 de 1
    • Locate the blue film attached to the circuit box containing the charging port.
    • Detach the blue film from the box.
  15. Sony SRS-XB30 Charging Port Replacement: étape 15, image 1 de 1
    • Detach the yellow, black and red wires by pulling them directly up.
  16. Sony SRS-XB30 Charging Port Replacement: étape 16, image 1 de 2 Sony SRS-XB30 Charging Port Replacement: étape 16, image 2 de 2
    • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
  17. Sony SRS-XB30 Charging Port Replacement, Charging Port: étape 17, image 1 de 1
    • Locate the circuit box containing the yellow charging port.
    • Remove the circuit box from any attachments connecting it to the speaker.
  18. Sony SRS-XB30 Charging Port Replacement: étape 18, image 1 de 1
    • Insert a new circuit box.
4 autres ont terminé cette réparation.
Star Dragon
Membre depuis le 04/09/18
645 Réputation
3 tutoriels rédigés
8 commentaires
Hi where I can find new circuit box?
cesar2_realmadrid - Réponse
YEAH - WERE DO YOU GET A REPLACEMENT?
Cheers
Tim
Tim Terry - Réponse
That’s right , at the very beginning it says that no parts are needed , what about the new charging port where can we get it?
Julio aguilar 44 - Réponse
I am incredibly curious, and a little bit excited, to hear what it is that was going through your mind at the start of this in comparison to when you reached the end? The exact moment that the very title of this article says very clearly the word “replacement” and then to see the amazing luck of the mistaken omission which read “No Parts Required” only to then be let down again when you realized that a part was in fact required. After-all it is called “Charging Port Replacement” so I’m sure you probably healed up pretty quick from the heartbreak you suffered.
John Wick -
Very clear instructions, thanks.
Any idea where I can find a new charging port for my speaker? Can’t find anything on the internet..
Thanks by advance
Dries
driesdebrauwer123 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 28
30 derniers jours : 112
Total : 13,102
