Introduction
In this guide we will be taking the smart watch out of its housing to remove its screen in order to reach the interior components. This process will only require a small tool with a flat edge.
Pièces
Aucune pièce nécessaire.
Detach the smart watch from the band by pushing on the back of the watch housing.
  • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
  • Set aside the power button and watch band as they are no longer needed for further disassembly.
Ajouter un commentaire
Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
Set aside the detached LCD screen to access the battery.
  • Set aside the detached LCD screen to access the battery.
To reassemble your device, follow these steps in reverse order.
Vincent Shiue
Membre depuis le 22/01/2018
229 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G5, Freund Spring 2018 Membre de l'équipe IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 45
Total : 254
