Introduction
This guide aims at instructing Sony TCM-919 owners on the process required to replace the speaker component of the device. If the speaker is producing sub-optimal sound or no sound at all, this guide can be advantageous.
Turn the device around so that the back cover is facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
  • Turn the device around so that the back cover is facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
  • Remove any batteries.
Ajouter un commentaire
Remove the 5, 5.95mm screws as indicated in the picture.
  • Remove the 5, 5.95mm screws as indicated in the picture.
Look to the back of the top cover. Desolder the two wires from the speaker.
  • Look to the back of the top cover.
  • Desolder the two wires from the speaker.
Squeeze the two prongs holding the speaker in place and remove the metal piece. Remove the speaker by gently lifting it up from the cover and pulling.
  • Squeeze the two prongs holding the speaker in place and remove the metal piece.
  • Remove the speaker by gently lifting it up from the cover and pulling.
Marygayle Martin
Membre depuis le 23/10/2014
501 Réputation
5 tutoriels rédigés
Équipe
Baylor, Team 4-3, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 160
