Introduction
Repairing/replacing the DVD drive.
Pièces
Aucune pièce nécessaire.
Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  • Turn the laptop upside down
  • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Ajouter un commentaire
As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
  • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
  • You should now be able to pull the battery out.
Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
  • Remove the four 16mm Phillips screws bordering the edge of the laptop, indicated here.
Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports. This will release the speaker grille.
  • Remove the 4mm Phillips screw on the right rear side of the laptop next to the audio ports.
  • This will release the speaker grille.
Flip the computer back over and open the screen.
  • Flip the computer back over and open the screen.
Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward.  The grille will still be connected by a white electrical strip. Carefully pull out the white electrical strip. Carefully pull out the white electrical strip.
  • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
  • Carefully pull out the white electrical strip.
Remove the 4mm Phillips screw in the center (located to the left of the green strip). Carefully pull the green strip straight up to disconnect it. The keyboard can now be removed.
  • Remove the 4mm Phillips screw in the center (located to the left of the green strip).
  • Carefully pull the green strip straight up to disconnect it.
  • The keyboard can now be removed.
Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive. Carefully remove the copper wire strip.
  • Remove the 4mm Phillips screw that connects the hard drive cage to the DVD drive.
  • Carefully remove the copper wire strip.
Slide the DVD drive out. Slide the DVD drive out. Slide the DVD drive out.
  • Slide the DVD drive out.
Sara Lillard
Membre depuis le 11/04/2011
93 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 12-36, Maness Spring 2011 Membre de l'équipe Cal Poly, Team 12-36, Maness Spring 2011
CPSU-MANESS-S11S12G36
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,544
