Aller au contenu principal
Sony VAIO PCG-F360 Speaker Replacement
Ce dont vous avez besoin
  1. Sony VAIO PCG-F360 Speaker Replacement, Battery: étape 1, image 1 de 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Replacement: étape 2, image 1 de 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Replacement: étape 3, image 1 de 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Replacement: étape 4, image 1 de 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: étape 5, image 1 de 3 Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: étape 5, image 2 de 3 Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: étape 5, image 3 de 3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Replacement: étape 6, image 1 de 3 Sony VAIO PCG-F360 Speaker Replacement: étape 6, image 2 de 3 Sony VAIO PCG-F360 Speaker Replacement: étape 6, image 3 de 3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony VAIO PCG-F360 Speaker Replacement, Speaker: étape 7, image 1 de 2 Sony VAIO PCG-F360 Speaker Replacement, Speaker: étape 7, image 2 de 2
    • The two speakers are located on the ends of the panel.
    • There are two screws holding each speaker. Remove them using a #00 Philips head screw driver.
  8. Sony VAIO PCG-F360 Speaker Replacement: étape 8, image 1 de 1
    • Carefully flip the speaker over and replace or clean the needed parts.
Hannah Millea
Membre depuis le 03/11/14
401 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-5, Calaway Spring 2014 Membre de l'équipe UMass Dartmouth, Team 3-5, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G5
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 180
