Introduction
This guide will show Sony Vaio owners how to repair individual keys on their keyboard.
Pièces
Aucune pièce nécessaire.
Open your computer.
  • Open your computer.
    • Make sure the computer is turned off.
Ajouter un commentaire
Find the broken key.
  • Find the broken key.
    • The S key is our example though it is not broken.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Insert the plastic spudger underneath the edge of the key. Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  • Insert the plastic spudger underneath the edge of the key.
  • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
  • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
  • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
  • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
Congratulations! You have successfully replaced a key on your keyboard.
Jennifer Pache
Membre depuis le 30/10/2017
301 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 20
Total : 101
