Aller au contenu principal
Sony Vaio VGN-TXN25N Optical Drive Replacement
Ce dont vous avez besoin
  1. Sony Vaio VGN-TXN25N Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip the computer so that the bottom is facing up.
    • Look to the long edge where the computer screen is hinged and find the "release slide". It is located at the top left corner of the square indent.
  2. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 2, image 1 de 1
    • Use your finger to slide the release to the left.
  3. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 3, image 1 de 2 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 3, image 2 de 2
    • While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide it out.
  4. Sony Vaio VGN-TXN25N Optical Drive Replacement, Keyboard: étape 4, image 1 de 1
    • Take out the screw in the center of the computer.
  5. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 5, image 1 de 1
    • Flip the computer right side up.
    • Open screen so that keyboard is visible.
  6. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 6, image 1 de 2 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool to gently lift the keyboard at a corner.
    • Make sure you get below the keyboard itself and not just the keys.
    • Slide the tool around the perimeter of the keyboard and it will start to lift.
  7. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 7, image 1 de 2 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 7, image 2 de 2
    • Do not pull the keyboard away from the computer. There is a ribbon cord attaching the keyboard to the computer.
    • Once the keyboard has been lifted at a few edges, lift the keyboard with both hands.
  8. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 8, image 1 de 3 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 8, image 2 de 3 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 8, image 3 de 3
    • Locate the ribbon cord behind the keyboard.
    • Locate a brown clamp attaching the keyboard to the computer.
    • Use a plastic opening tool to lift the clamp and release the cable.
    • Now the keyboard can be pulled away entirely.
  9. Sony Vaio VGN-TXN25N Optical Drive Replacement, Hard Disk Drive: étape 9, image 1 de 1
    • Take out the screw under the keyboard.
  10. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 10, image 1 de 1
    • Flip computer over and remove the 6 screws.
  11. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 11, image 1 de 1
    • Flip computer over again and unclip the plastic cover.
    • Do not be afraid to be rough, since the cover is hard to remove.
    • Be sure to remove the case slowly and unclip any ribbon cords that are attached.
  12. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 12, image 1 de 2 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 12, image 2 de 2
    • Locate the hard drive disk. The hard drive disk will be covered by a shiny lid.
    • Unscrew the lid with a #00 Phillips Head Screwdriver.
    • There are 3 screws holding it in.
    • Grab the lid by one corner and pull off the lid.
  13. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 13, image 1 de 1
    • Find the brown clip attached to the hard disk drive on the side facing the optical disk drive.
    • Carefully pull out the brown clip with your fingers.
  14. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 14, image 1 de 1
    • Hold the hard disk drive on the side where the brown clip was attached and lift it upwards to pull it out.
  15. Sony Vaio VGN-TXN25N Optical Drive Replacement, Optical Drive: étape 15, image 1 de 3 Sony Vaio VGN-TXN25N Optical Drive Replacement, Optical Drive: étape 15, image 2 de 3 Sony Vaio VGN-TXN25N Optical Drive Replacement, Optical Drive: étape 15, image 3 de 3
    • Remove the 3 indicated screws.
    • There are two small scews arounds the edge and one is on top of the optical drive.
  16. Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 16, image 1 de 2 Sony Vaio VGN-TXN25N Optical Drive Replacement: étape 16, image 2 de 2
    • Remove the optical drive from resting positions.
    • Gently remove cord.
Luke Thornley
Membre depuis le 04/03/12
87 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-3, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 1,680
