Introduction
The keyboard should be replaced if it is missing keys or non-functional.
Pièces
Aucune pièce nécessaire.
Power off the laptop.
  • Power off the laptop.
  • Unplug the charging cable and any other cables plugged into the laptop.
  • Failure to remove or unplug any cables could result in electric shock.
  • Turn the laptop over so that the back panel is facing upwards.
Ajouter un commentaire
Locate two switches above the battery that lock it into place.
  • Locate two switches above the battery that lock it into place.
  • Push the left-hand switch, that says "lock" above it, so that it is unlocked.
Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
  • Push and hold the right-hand switch, which says "release" above it, and lift the battery up out of its place.
Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
  • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
  • There will be three dots next to the desired screws
Grip the cover of the optical drive and slide it out.
  • Grip the cover of the optical drive and slide it out.
  • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Remove all the 8mm Phillips #1 screws on the backside of the laptop. There are three 3mm and two 5.3mm screws under the battery that also need to be taken out. There are three 3mm screws under the optical drives that also need to be taken out.
  • Remove all the 8mm Phillips #1 screws on the backside of the laptop.
  • There are three 3mm and two 5.3mm screws under the battery that also need to be taken out.
  • There are three 3mm screws under the optical drives that also need to be taken out.
  • Remove the RAM panel in addition to the other screws. For further instructions, refer to the RAM replacement guide.
Pry along the edges of the back panel using the spudger. If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again. If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
  • Pry along the edges of the back panel using the spudger.
  • If you are struggling to remove the back panel with a moderate amount of force, do NOT apply any additional force, instead double check to make sure all the screws were removed before attempting again.
Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
  • Locate and remove three 5.3 mm Phillips #1 screws on the bottom of the fan.
  • Locate and remove the four 5.3 mm Phillips #1 screws on the top of the fan.
Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
  • Locate and remove the four 3mm Phillips #1 screws above the processor and attached to the bronze heat-pipes.
  • Gently lift up the fan and heatsink from the the laptop.
  • If the fan and heatsink will not lift up with ease, do NOT apply any additional force. Check again to see if all necessary screws are removed.
The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
  • The fan attached onto the heat sink with electrical tape. Removing the electrical tape allows you to replace the fan.
Locate the two highlighted circular openings and push the keyboard out.
  • Locate the two highlighted circular openings and push the keyboard out.
  • There is a ribbon cable attaching the keyboard to the back of the motherboard. Avoid damaging the ribbon when pushing out the keyboard.
Detach the ribbon cable to separate the keyboard from the laptop.
  • Detach the ribbon cable to separate the keyboard from the laptop.
  • Push open the brown clamp at the base of the ribbon to release it.
4 autre(s) ont terminé cette réparation.
Kevin McGowan
Membre depuis le 22/04/2014
512 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-17, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 88
Total : 4,908
