Introduction
How to get out the RAM of your Sony Vaio VGN-S260
Pièces
Aucune pièce nécessaire.
Flip the laptop over so the Vaio logo is facing down Locate the battery at the top and Find the release and unlock slides on the battery Slide the unlock tab to the unlock position
  • Flip the laptop over so the Vaio logo is facing down
  • Locate the battery at the top and Find the release and unlock slides on the battery
  • Slide the unlock tab to the unlock position
  • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab
Ajouter un commentaire
With the tabs still in the unlock position, slide the battery away from the main case. With the tabs still in the unlock position, slide the battery away from the main case.
  • With the tabs still in the unlock position, slide the battery away from the main case.
With the laptop still flipped over with the Vaio logo facedown, locate the screws for the RAM Remove the screws
  • With the laptop still flipped over with the Vaio logo facedown, locate the screws for the RAM
  • Remove the screws
Lift off the unscrewed cover
  • Lift off the unscrewed cover
  • Locate the RAM
Locate tabs next to RAM Pull the 2 tabs away from the RAM The RAM should pop up.
  • Locate tabs next to RAM
  • Pull the 2 tabs away from the RAM
  • The RAM should pop up.
Gently slide the RAM up and out
  • Gently slide the RAM up and out
Jeffrey Bryan
Membre depuis le 20/04/2010
544 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 16-4, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 membres
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,456
