Introduction
How to remove the upper casing of the Sony Vaio VGN-S260 laptop
Pièces
Aucune pièce nécessaire.
Flip the laptop over so the Vaio logo is facing down Locate the battery at the top and Find the release and unlock slides on the battery Slide the unlock tab to the unlock position
  • Flip the laptop over so the Vaio logo is facing down
  • Locate the battery at the top and Find the release and unlock slides on the battery
  • Slide the unlock tab to the unlock position
  • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab
Ajouter un commentaire
With the tabs still in the unlock position, slide the battery away from the main case. With the tabs still in the unlock position, slide the battery away from the main case.
  • With the tabs still in the unlock position, slide the battery away from the main case.
Flip the computer over so the Vaio logo is facedown Unscrew the 2 screws next to the battery
  • Flip the computer over so the Vaio logo is facedown
  • Unscrew the 2 screws next to the battery
Flip the computer over again so the Vaio logo is face up
  • Flip the computer over again so the Vaio logo is face up
  • Open the lid
Press down on the outer gray shell around the keyboard Use the spudger to gently lift keyboard
  • Press down on the outer gray shell around the keyboard
  • Use the spudger to gently lift keyboard
  • Do not pull up the keyboard too far as it is attached to a ribbon underneath
There are 2 spring-held latches, one above the F4 and one above the F12. Push a latch up into the frame of the keyboard, then lift the keyboard gently in that area so the latch doesn't spring back. Then push the other latch and the keyboard will be released.
Yishai Sered - Réponse
Lift up lever underneath the ribbon to detach the keyboard. Lift up lever underneath the ribbon to detach the keyboard.
  • Lift up lever underneath the ribbon to detach the keyboard.
Remove memory/wireless compartment cover
  • Remove memory/wireless compartment cover
Flip so the Vaio Logo is face down Locate and remove a total of 8 screws on the bottom. Locate and remove a total of 8 screws on the bottom.
  • Flip so the Vaio Logo is face down
  • Locate and remove a total of 8 screws on the bottom.
There are 2 more screws on the bottom, one in the middle of the front next to the flash stick socket, and one under the memory door.
Find and remove 5 screws (they all have arrows next to them) from cover
  • Find and remove 5 screws (they all have arrows next to them) from cover
Flip the laptop over so the Vaio logo is face up Use the spudger to pop up the upper casing Do not lift too much as the Uppercasing is attached to wires underneath
  • Flip the laptop over so the Vaio logo is face up
  • Use the spudger to pop up the upper casing
  • Do not lift too much as the Uppercasing is attached to wires underneath
  • Remove the wires that are attaching the uppercasing to the motherboard
There are also 5 screws from the top of the uppercasing.
The are 4 cables to remove: flat cable for the power and S buttons at top center; flat cable for the touchpad at bottom center; and 2 twisted pairs for the speakers.
The speaker cable socket is very delicate. If all you are getting at is the CPU or the hard drive, it may be enough to disconnect the flat cables and gently rotate the uppercasing shifting it left to allow access to the right-hand side with the CPU fan and the hard drive.
The top panel has cutouts that allow the cables to be disconnected before the top of the case is removed. The two flat cables are not clamped and can be pulled vertically out of their connectors. The delicate speaker cables are connected to the motherboard with plugs which can be gently levered up out of their sockets.
roberttrevellyan - Réponse
Remove the uppercasing
  • Remove the uppercasing
2 autre(s) ont terminé cette réparation.
Jeffrey Bryan
Membre depuis le 20/04/2010
544 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 16-4, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 membres
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 4,266
