Introduction
If your Walkman will not turn on and you are certain that the batteries are new or fully charged, you may need to replace the device's power switch. To do so, you will need a spudger and soldering iron.
Pièces
Aucune pièce nécessaire.
Remove any batteries or cassettes from the Walkman.
  • Remove any batteries or cassettes from the Walkman.
Ajouter un commentaire
Using a spudger, separate the back cover from the front. Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell. Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  • Using a spudger, separate the back cover from the front.
  • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
Gently pull the ribbon from the jack above the film revolver, near the edge. Lift the motherboard from the outer shell.
  • Gently pull the ribbon from the jack above the film revolver, near the edge.
  • Lift the motherboard from the outer shell.
  • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
Identify the six points where the power switch is soldered to the motherboard.
  • Identify the six points where the power switch is soldered to the motherboard.
  • Using a soldering iron, remove the switch by de-soldering these points which hold it in place.
Wilson Riforgiat
Membre depuis le 11/09/2014
572 Réputation
4 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Membre de l'équipe USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 membres
14 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 775
