Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers. Insert plastic opening tool in the corner of device and slide along edges to separate adhesive Remove cover
  • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
  • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
  • Remove cover
Ajouter un commentaire
Locate the SD card reader in the bottom left hand corner
  • Locate the SD card reader in the bottom left hand corner
  • Remove all screws connecting the metal plate to the device.
After all the screws have been removed lift the circuit board up to wiggle free.
  • After all the screws have been removed lift the circuit board up to wiggle free.
After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
  • After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
  • Once placed there lift up and disconnect the SD card reader from the device.
Martin Luna
Membre depuis le 24/09/2014
1 504 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 15-6, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 22
Total : 1,385
