Aller au contenu principal
Sony XPERIA Tablet Z Volume Button Replacement
Ce dont vous avez besoin
  1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: étape 1, image 1 de 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: étape 1, image 2 de 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: étape 1, image 3 de 3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
    • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
  2. Sony XPERIA Tablet Z Volume Button Replacement, Locate the Volume module: étape 2, image 1 de 1
    • Locate the volume module.
    • Remove both screws using the Philips screwdriver.
  3. Sony XPERIA Tablet Z Volume Button Replacement, Lift out of Place: étape 3, image 1 de 1
    • Once both screws are removed grab the tweezers.
    • Then lift up on the module.
  4. Sony XPERIA Tablet Z Volume Button Replacement, Removing the Electrical tape: étape 4, image 1 de 1
    • Find the electrical tape connecting the module to the motherboard
    • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
Martin Luna
Membre depuis le 09/24/14
1 858 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 15-6, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 8
Total : 2,396
