Introduction
For this model ,removing the Logic board is very difficult operation!!!! If you do something wrong, you may damage the board.
Please SUBSCRIBE to my channel ツ
Vidéo d'introduction
Warm the Back Cover. You can use a hairdryer. Be careful, the Cover is plastic. Use a small suction cup and plastic tools for separating the Rear panel.
  • Warm the Back Cover. You can use a hairdryer.
  • Be careful, the Cover is plastic.
  • Use a small suction cup and plastic tools for separating the Rear panel.
  • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
One battery
One camra lance back
Prince Kushwah - Réponse
Disconnect the Battery Cable. The battery is stuck to the phone fame. Use the white tape to remove it. Li-Polymer Battery, 2230 mAh
  • Disconnect the Battery Cable.
  • The battery is stuck to the phone fame. Use the white tape to remove it.
  • Li-Polymer Battery, 2230 mAh
  • Part number: LIS1551ERPC
  • Please SUBSCRIBE to my channel ツ
если первая разборка, отклеивается очень сложно и я бы советовал нагреть модуль до 70-76, на сепараторе. тогда аккумулятор отклеится легче. =)
Владимир Гусев - Réponse
Remove the SIM and the memory cards. Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
  • Remove the SIM and the memory cards.
  • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
Ajouter un commentaire
Disconnect one by one:
  • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector. Put one plastic spudger between the Logic board and the Main frame.
  • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
  • Put one plastic spudger between the Logic board and the Main frame.
Step one: move aside less the left side of the board - down. Step two: the left side of the Logic board must go out of the main frame. For this manipulation use only plastic tools.
  • Step one: move aside less the left side of the board - down.
  • Step two: the left side of the Logic board must go out of the main frame.
  • For this manipulation use only plastic tools.
15 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
150 367 Réputation
424 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 50
30 derniers jours : 208
Total : 11,403
