Introduction
We will show the user how to access and remove the phones loud speaker module.
Pièces
Aucune pièce nécessaire.
Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off. Use the plastic opening tool to pry the top plastic section off.
  • Use the plastic opening tool to pry the top plastic section off.
Ajouter un commentaire
Use the plastic opening tool to pry the bottom plastic section off. Use the plastic opening tool to pry the bottom plastic section off.
  • Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws. Use the plastic opening tool to pry off the back. Use the plastic opening tool to pry off the back.
  • Remove the four 5mm screws.
  • Use the plastic opening tool to pry off the back.
Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module. Use the plastic opening tool to remove the loud speaker module.
  • Use the plastic opening tool to remove the loud speaker module.
Adam Giniger
Membre depuis le 22/09/2014
1 148 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 4-4, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 174
