Introduction
In order to remove other parts of your device, you will need to remove the back assembly. You may also need to replace the back panel if it damaged. This guide will show you how to remove the back assembly of your Sony Xperia XA1 Ultra. A heat gun or hairdryer is needed to loosen the adhesive to open the back panel, which can become hot and potentially damage the phone. A suction cup and opening tools will be needed to pry off the cover.
Wedge your finger under the bottom ridge of the SD card insert. Pull outwards with your fingers to remove the SD card from the left side of device.
  • Wedge your finger under the bottom ridge of the SD card insert.
  • Pull outwards with your fingers to remove the SD card from the left side of device.
How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
Kyle Ladtkow - Réponse
Use a hair dryer to heat each corner of the phone.
  • Use a hair dryer to heat each corner of the phone.
  • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
  • Don't heat one area for too long; the phone may get damaged from overheating.
Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Press a suction cup on a heated corner of the device.
  • Press a suction cup on a heated corner of the device.
  • Hold the phone down and gently lift the suction cup to create a small gap.
  • You may hear crunching or popping sounds when you lift up the back cover.
Ajouter un commentaire
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
  • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
  • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Period missing for first point.
Slide your plastic card along the side of your phone to loosen the adhesive.
  • Slide your plastic card along the side of your phone to loosen the adhesive.
  • Move the card along the sides of the phone to lift all of the corners.
Can you clarify what should be repeated in this step?
Tiffany Dang - Réponse
Lift up the back cover by lifting up the sides of the phone with your hand.
  • Lift up the back cover by lifting up the sides of the phone with your hand.
  • Apply a new strip of adhesive for reassembly.
Jacob Jung
Membre depuis le 18/04/2018
1 143 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 31
Total : 72
