Aller au contenu principal
Sony Xperia XA1 Ultra Battery Replacement
Ce dont vous avez besoin
  1. Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: étape 1, image 1 de 2 Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: étape 1, image 2 de 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Battery Replacement: étape 2, image 1 de 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Battery Replacement: étape 3, image 1 de 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Battery Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Battery Replacement: étape 5, image 1 de 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Battery Replacement: étape 6, image 1 de 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Battery Replacement, Battery: étape 7, image 1 de 3 Sony Xperia XA1 Ultra Battery Replacement, Battery: étape 7, image 2 de 3 Sony Xperia XA1 Ultra Battery Replacement, Battery: étape 7, image 3 de 3
    • Peel off the two pieces of black tape covering the battery with your hands.
  8. Sony Xperia XA1 Ultra Battery Replacement: étape 8, image 1 de 2 Sony Xperia XA1 Ultra Battery Replacement: étape 8, image 2 de 2
    • Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
  9. Sony Xperia XA1 Ultra Battery Replacement: étape 9, image 1 de 3 Sony Xperia XA1 Ultra Battery Replacement: étape 9, image 2 de 3 Sony Xperia XA1 Ultra Battery Replacement: étape 9, image 3 de 3
    • Wedge the iFixit Opening Tool underneath the battery.
    • Remove the battery by pulling up on the iFixit Opening Tool.
12 autres ont terminé cette réparation.
Jacob Jung
Membre depuis le 04/18/18
1 429 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team S16-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 membres
9 tutoriels rédigés
3 commentaires
magnificent…i successfully change a new battery for xperia xa1 ultra…its not the time yet for this xperia to retire from service to me…thank you very much
Wahyudi Hussaini - Réponse
Wher did you get the batterry from? And is it good as the original?
very Green -
Where can I get the original battery
very Green - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 24
Total : 10,083
