Aller au contenu principal
Sony Xperia XZ1 Compact Battery Replacement
Ce dont vous avez besoin
Instructions vidéo
6 autres ont terminé cette réparation.
Witrigs
Membre depuis le 11/24/15
69 454 Réputation
378 tutoriels rédigés
3 commentaires
This is a very good instruction for a job that has lots of work to do. Kudos for the author.
It took me about 2 hours to get my phone ready to use.
The hardest part was to remove the battery from the motherboard without braking anything.
Harri Vähätalo - Réponse
Réalisé en +/- 2h. Bien expliqué, merci !
Patrick JOACHIM - Réponse
Useful tip from @kire456 on youtube: "A tip for others: the glue strip along the edges of the screen is only 1.5mm wide, and behind the LCD screen is a very fragile reflective sheet of foil that is easily damaged. So make sure not to wedge your plastic card in deeper than you need to, when you are removing the LCD screen. I did, and damaged the reflective foil."
tony - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 128
Total : 10,580
