Aller au contenu principal
Sony Xperia Z - Password Removal, Firmware Update with PC Companion
Vidéo d'introduction
  1. Sony Xperia Z - Password Removal, Firmware Update with PC Companion, Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 1, image 1 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion, Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 1, image 2 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion, Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 1, image 3 de 3
  2. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 2, image 1 de 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 2, image 2 de 2
    • Install Sony PC Companion in your PC.
  3. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 3, image 1 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 3, image 2 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 3, image 3 de 3
    • From here you can update your firmware, but when you connect the phone, it must be switched on and not in security or password screen.
    • We will start "Support Zone" because from here we can flash the phone from switched off state regardless of whether there is a password.
    • Now start "Phone / Tablet Software Update".
  4. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 4, image 1 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 4, image 2 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 4, image 3 de 3
    • Connect your laptop to power supply since the update of your phone will take some time.
    • Now choose "repair my phone / tablet". By this way you can fully erase your phone and remove any security password, PIN etc., or change firmware if your phone have OS problem and can't be powered on correctly.
    • This is your last warning about losing your personal data.
  5. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 5, image 1 de 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 5, image 2 de 2
    • PC Companion will download some files to prepare your PC for software update
    • Your phone / tablet must be at last 80% for the update to proceed safely!
  6. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 6, image 1 de 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 6, image 2 de 2
    • Select the model of your phone.
    • You should not confuse the model.
  7. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 7, image 1 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 7, image 2 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 7, image 3 de 3
    • The USB cable must be connected only to the PC.
    • Turn off the phone.
    • Press and hold the Volume Down button while plugging the cable into your phone.
    • Once connected, PC Companion will download necessary firmware and will upload it to your phone.
  8. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 8, image 1 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 8, image 2 de 3 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 8, image 3 de 3
    • Your PC must recognize your phone like SOMC Flash Device.
    • If you have a problem with drivers (your PC can't recognize your phone), search in the internet for "S1Boot Fastboot" drivers or use the link below.
    • Android WinUSB drivers
  9. Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 9, image 1 de 2 Sony Xperia Z - Password Removal, Firmware Update with PC Companion: étape 9, image 2 de 2
    • When PC Companion finished with update process, disconnect the phone and switch it on.
    • Now your phone is in factory condition, with erased custom data and without password protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
31 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 368 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 468 tutoriels rédigés
4 commentaires
the Sony Xperia Z C0682 is not in the model list. What should I do ?
Warren Razon - Réponse
pls i have sony xperia Zc c80682 and the touch is not working
daniel bentil addison - Réponse
thanks it works
Aung kyaw Oo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 53
Total : 63,621
