Introduction
Sony Xperia Z2 (D6502, D6503, and D6543) - How to replace the Main Camera.
Please SUBSCRIBE to my channel ツ
Outils
Aucun outil requis.
Vidéo d'introduction
Switch off the phone. If you can't switch it off, you can use the OFF button near to the SIM card Tray. Warm the Back Cover. You can use a hairdryer.
  • Switch off the phone.
  • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
  • Warm the Back Cover. You can use a hairdryer.
  • Be careful, the Back Cover is plastic.
Ajouter un commentaire
Use a small suction cup and plastic tools for separating the Rear panel. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s. There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  • Use a small suction cup and plastic tools for separating the Rear panel.
  • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape). Please SUBSCRIBE to my channel  ツ
  • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
  • Please SUBSCRIBE to my channel ツ
Should include the information about the NFC antenna.
Sounds like a dealbreaker for some people.
Diogo Pinheiro - Réponse
What about it?
Makos - Réponse
Disconnect the Battery. Disconnect the Camera from the Logic board and replace it with the new one.
9 autre(s) ont terminé cette réparation.
ZFix
Membre depuis le 09/12/2013
150 220 Réputation
424 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - Réponse
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - Réponse
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - Réponse
the camera have like a coil for do the focus, may be you short circuit it during the replace. There is 10 and 15 US replace camera from china at ebay. Try at fixez dot com
deftoner -
Hi, I replaced back camera in my Sony Xperia Z3c but it still doesn't work. It shows black screen. Do you think it's something which can be solved?
lucia.quitadamo - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 87
Total : 7,654
