Introduction
Remove the main flex cable from the Sony Xperia Z3 Compact motherboard. This includes the button cable.
First, heat up. And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover. Finally, remove the back cover.
  • First, heat up.
  • And then place the suction cup and pull to open a gap. Insert into the guitar pick to cut the adhesive sticker under the back cover.
  • Finally, remove the back cover.
Ajouter un commentaire
Disconnect the battery. Unscrew the screws holding the black midframe in place. Remove back frame.
  • Disconnect the battery.
  • Unscrew the screws holding the black midframe in place.
  • Remove back frame.
Remove rear camera bracket. Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows. Remove rear camera.
  • Remove rear camera bracket.
  • Release connector, but take care not to damage the electronic components next to the connector. It is best to access the connector from the bottom (battery side), and not from the side as the picture shows.
  • Remove rear camera.
Release connectors and screw. Release connectors and screw. Release connectors and screw.
  • Release connectors and screw.
Remove motherboard. Remove motherboard. Remove motherboard.
  • Remove motherboard.
be very careful with the flex cable that is connected to the vibrator, it is very easy to break that when removing motherboard
anonymous 8554 - Réponse
vibrator with orange silicon cover is fixed with sticker. you better pull it off with spudger before removing the motherboard
jibou1356 - Réponse
yup, broke mine. Should've come here first. I'll leave it the way it is. I'm not replacing the entire main flex just for this.
PETRISOR M - Réponse
Remove main flex. Remove main flex. Remove main flex.
  • Remove main flex.
5 autre(s) ont terminé cette réparation.
Sophia
Membre depuis le 25/03/2014
38 963 Réputation
111 tutoriels rédigés
hi dear
my mobile (sony xperia z3 mini ) it problem in screen, i changed screen but still not work always black how can i do to fixed my mobile ???? plz help me
BR
Swren
swren1987 - Réponse
I can not loosen a screw, what can I do?
Piero Sabino - Réponse
Hey Fixit, I will repair my Wifi, but I can not find the component parts on the mainboard on the Z3c
Have a description where is the wifi component similar to these video because on the Z3Compact?
http://www.youtube.com/watch?v=dvq1zkiu4...
Sofie - Réponse
is there label imei or meid in it ???
Ardians Faqih - Réponse
Yes, there is a label in the phone with IMEI info. For some reason, it’s not show on the pictures, but you can see the label simply by opening the bottom port cover on the left side of the phone and pulling on it. The IMEI is the number written on the top right of the label.
axel -
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 34
30 derniers jours : 173
Total : 13,575
