Aller au contenu principal
Sony Xperia Z3 Dual Loudspeaker Assembly Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: étape 1, image 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: étape 1, image 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement, Loudspeaker Assembly: étape 1, image 3 de 3
    • Heat to soften back cover sticker.
    • Place the suction cup and try to open a gap.
    • Insert the guitar pick into the gap.
  2. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 2, image 1 de 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 2, image 2 de 2
    • Slide the guitar pick to cut the sticker and remove the back cover.
  3. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 3, image 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 3, image 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 3, image 3 de 3
    • Remove two screws by Philips screwdriver.
    • Release all the connectors connecting with loudspeaker assembly.
    • Remove the small vibrator securing bracket.
  4. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 4, image 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 4, image 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 4, image 3 de 3
    • Remove the securing cover. It's thin and weak, please be careful when remove it.
  5. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 5, image 1 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 5, image 2 de 3 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 5, image 3 de 3
    • Pry up the assembly and carry it out.
  6. Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 6, image 1 de 2 Sony Xperia Z3 Dual Loudspeaker Assembly Replacement: étape 6, image 2 de 2
    • Remove the loudspeaker assembly finally. Be careful with the flex beside assembly.
4 autres ont terminé cette réparation.
Sophia
Membre depuis le 03/25/14
43 810 Réputation
62 tutoriels rédigés
2 commentaires
this is all good but is there a link to the part ?
morten hundevad - Réponse
EBay search Sony z3 replacement loud speaker cost's around £3-£5
Martin Lb -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 4,396
