Aller au contenu principal
Sony Xperia Z5 Compact Screen Replacement
Ce dont vous avez besoin
  1. Sony Xperia Z5 Compact Screen Replacement, Charging port flex: étape 1, image 1 de 2 Sony Xperia Z5 Compact Screen Replacement, Charging port flex: étape 1, image 2 de 2
    • Power off and remove SIM card tray.
  2. Sony Xperia Z5 Compact Screen Replacement: étape 2, image 1 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 2, image 2 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 2, image 3 de 3
    • Heat up the back cover to soften the adhesive.
    • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
    • Remove back cover.
  3. Sony Xperia Z5 Compact Screen Replacement: étape 3, image 1 de 2 Sony Xperia Z5 Compact Screen Replacement: étape 3, image 2 de 2
    • Remove all 10 Phillips screws.
    • Disconnect NFC clip and flashlight clip.
  4. Sony Xperia Z5 Compact Screen Replacement: étape 4, image 1 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 4, image 2 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 4, image 3 de 3
    • Remove the plastic bracket.
    • Pry up and remove back frame.
  5. Sony Xperia Z5 Compact Screen Replacement: étape 5, image 1 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 5, image 2 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 5, image 3 de 3
    • Remove front camera.
  6. Sony Xperia Z5 Compact Screen Replacement: étape 6, image 1 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 6, image 2 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 6, image 3 de 3
    • Remove rear camera.
  7. Sony Xperia Z5 Compact Screen Replacement: étape 7, image 1 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 7, image 2 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 7, image 3 de 3
    • Remove loudspeaker.
  8. Sony Xperia Z5 Compact Screen Replacement: étape 8, image 1 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 8, image 2 de 3 Sony Xperia Z5 Compact Screen Replacement: étape 8, image 3 de 3
    • Release charging port connector.
    • Remove plastic protective bar.
    • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
  9. Sony Xperia Z5 Compact Screen Replacement: étape 9, image 1 de 1
    • Remove charging port flex.
  10. Sony Xperia Z5 Compact Screen Replacement, Screen: étape 10, image 1 de 2 Sony Xperia Z5 Compact Screen Replacement, Screen: étape 10, image 2 de 2
    • Remove the motherboard/battery assembly.
    • Using a spudger, release the battery connector from the motherboard.
  11. Sony Xperia Z5 Compact Screen Replacement: étape 11, image 1 de 2 Sony Xperia Z5 Compact Screen Replacement: étape 11, image 2 de 2
    • Using a suction cup, create a space between the screen and the phone.
    • Using an opening tool, pry the LCD screen up.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 6
Total : 766
