Introduction
If your sound card is damaged or broken or you're having trouble with the sound within your laptop, replace the sound card using this guide.
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Ajouter un commentaire
Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Use the tweezers to remove the two connecting wires.
  • Use the tweezers to remove the two connecting wires.
Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
  • Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
Lift and pull the sound card away from the computer.
  • Lift and pull the sound card away from the computer.
Armani Tayeh
Membre depuis le 19/03/2018
411 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G2, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G2, Peak Spring 2018
UMASSD-PEAK-S18S3G2
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 9
