Aller au contenu principal
Spin Master Boxer Robot Screen Replacement
Ce dont vous avez besoin
  1. Spin Master Boxer Robot Screen Replacement, Robot Screen: étape 1, image 1 de 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Screen Replacement: étape 2, image 1 de 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Screen Replacement: étape 3, image 1 de 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Screen Replacement: étape 4, image 1 de 2 Spin Master Boxer Robot Screen Replacement: étape 4, image 2 de 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Screen Replacement: étape 5, image 1 de 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
Lauren Roide
Membre depuis le 04/16/19
739 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S1-G1, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 457
